i used vortex and the car ran like shyt, optimax is good but ive had some bad batches i mainly use ultimate and never had any drama's and if i cant get ultimate i fill up with mobile synergy 8000 (lucky its just down the road) but not many places in the illawarra have it, and ive found that 8000 is pretty sweet too
ben...
I usually use Ultimate but when I can't make it to the BP I use Vortex from Caltex. At 16psi, 240rwkw on a good tune I notice absolutely no difference whatsoever between the fuels.
well with mine there was a sh1t load of difference on the dyno-BP Ultimate always gave a better power figure and even better power curve than Vortex. Couldnt even get to 22 psi on Vortex due to knock concerns. Ther is no comparison and I ONLY use Ultimate
Edited by overev1
Go to this page on the BP web site;
http://www.bp.com.au/refineries/refineries.asp?menuid=d
Read this paragraph;
A particular feature of the Australian oil industry is the practice of refinery exchange, in which refining companies exchange products in various locations to minimise distribution costs. For example, BP supplies other companies in Perth and Brisbane and in return is supplied with product in Melbourne, Sydney and Tasmania.
Now tell me again why you think BP is better when it is made in the same refineries as all of the others?
:( cheers :(
meh Ultimate is all i've used since i've got the car, hada use shell once or twice when BP had that shortage or wateva... car didnt seem to like it, but yeah. ultimate is where its at.
You live in Victoria
There is no BP refinery in Victoria
The fuel you buy at BP service stations in Victoria is not made by BP
It is either made by Mobil at Altona or Shell at Geelong
:O cheers :(
Edited by Sydneykid
SK is on the money (As usual) If you live in QLD all your fuel comes from Caltex (My mate works there and is involved with mixing) the only difference is the different additives used by the different companies
That being said I seem to get bad running and poor ecconomy on shell but I am fine on the others
at last u guys have a choice f fuels here in west aus the only 98 we can get is bpultimate shell and caltex only do 91 @ 95 ron fuels here fyi vortex is actually rated @ 95 ron not 96 as they would like everyone to believe
My car was last tuned on Ultimate, so Ultimate it is. Aslo beieve in picking the busy BP's as they would have to stock up with fresher fuel, therefore my car always as fresher fuel! Over here in Adel the cops use Mobil........so i definatly steer clear of Mobil Stations!
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
