just wanted to hear some fuel reg opinons cause there are so many on the market its not funny. you see ones on ebay like obx for $90, and then ones like the sard version for $200, then the likes of SX etc. also i have heard that malpassi regs begin to fail to adequately hold pressure due to the middle section be made out of rubber and it suffers from detortion over time, whether this is correct or not i dont know.
thanks
https://www.sau.com.au/forums/topic/109771-fuel-regs/
Forgot where I read it but someone once said re regs that if they are anodised in pretty colours then its best to stay away. Sard is not anodised.
The main problem was consistency in holding the desired pressure mentioning that factory regs are hard to beat.
https://www.sau.com.au/forums/topic/109771-fuel-regs/#findComment-2022747
The Mines R34GTR uses the Nismo style that bolts directly onto the fuel rail. They are ~$150 from Nengun.
:O cheers :dry:
PS; so do I
Just like most other 550-650PS GTR's in Japan.
2rismo - To adjust the fuel pressure, you just tee a gauge into the fuel line between the pump and the rail, then turn the bolt clockwise to increase pressure or anticlockwise to decrease pressure. When you have the desired setting, lock with the nut.
Edited by Mik
https://www.sau.com.au/forums/topic/109771-fuel-regs/#findComment-2023128
  • 10 months later...
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
