For Sale: Complete RB25 package, mostly new, purchased for use in a R32 racing car, which due to rule changes is no longer allowed to run this set-up.
RB25 Neo Engine- From R34, VVT. Comes with GTR Rods and a brand new set of Ross Forged Pistons, rings and metal gasket. (Pic attached) All still in the box. Engine ready to be re-assembled, have left apart so buyer can further modify if desired. Good for a conservative and reliable 330kw at the wheels as is. $2,500
RB25 Gearbox- (pic attached) Brand new, never seen oil. Comes complete with brand new shifter still in the plastic. $2,600 for both
OS Geiken Clutch- (pic attached) Brand new still in the box. Twin Plate 450hp. Complete with bearing kit. $2,000
RB25 Apexi- (pic attached) Brand new still in the box with hand controller. $1,200
RB25 Wiring Harness- R34 VVT harness complete. $500
Everything is quality, purchased to put in to a State Series winning and reliable race car. (Finished all of its last 66 race starts dating back 3 years!) No dreamers please, all prices are under retail.
Everything is there to either upgrade a R32 GTS-t to be an awesome machine that will eat all but the best GTR's or hot up a R33 or R34.
Would prefer to sell as a complete package to a single buyer or group and will sell the lot for $7,500 ($8,800 is individual total). Retail for this package is around $10,500 to $11,000!!
Cheers
26Motorsport
https://www.sau.com.au/forums/topic/109793-complete-rb25-engine-package/
  • 1 year later...
Cheers
26Motorsport
  • 1 month later...
  • 3 months later...
Will the pistons suit a R33 RB25DET?
Yes they will and they are still sitting in a box brand new in my garage. Let me know if your interested
Cheers
Mark
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
