Anyone know what brand Dual or Single guage pods that best suit an R33 GTS25t for 60mm guages? Something that fits nicely and looks good... also what are prices and where do you recommend buying them from? I am in Perth. Any pictures would be great.
Chris
https://www.sau.com.au/forums/topic/1098-60mm-a-pillar-guage-pods/
I got a trust 60mm single universal guage pod from makspeed in melbourne (check the perfomance shops / wreckers in vic thread in the victoria forum). cost me $88, and i cut the prick down so that the shape matched my pillar. then i stuck 2 matal brackets with fibre glass on (one that slots b/w the pillar and the dash, and the other wraps around the pillar on the windscreen side). On the other side that goes towards the door, I stuck a piece of leather (b/c it streches only a little) and put a small bracket on that so it clips on that side. This way I made no holes or damage to my pillar. It fits VERY nicely and looks very professional. If I had a digital camera or access to one I would take pics and show off, but unfortunately, I dont :P
If you cant be stuffed doing all that (for me its a hobby), they sell dual pillar pods for R33's that fit straight on for about $130.
Zahos
Look at this thread. Makspeed is listed in there, they are in little bourke street. There is also an outlet in Maribyrnong, but that is mostly a workshop, and they dont really have any thing like that for sale there....
The one in Bourke st is b/w exhibition st and russel st
Zahos
so you have an R33?
doesnt the trust universal single pillar panel really fit nicely? needs a bit of cutting does it? what do you ppl with dual guages find the most useful? boost + (voltage/exhaust temp/oil or fuel pressure etc.. )
chris
Yeah b005t, R33!
I got the universal for 2 reasons:
- didnt want to pay a ridiculous price for a piece of fibleglass!
- only wanted 1 guage. This way you also save from buying another guage that you dont really want anyway...
At first, i was a bit cheesed that i had to cut it down, but in the end, i was glad that i took that approach b/c now it looks better than i hoped it would, and it is much smaller than oroginal size making look even neater! This way I made my own custom brackets to hold it on, and I didnt have to touch the pillar at all!
I try grab a digital camera here from work and take a pic for ya.
Zahos
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
