hey,
went down to the drags 2night, to see if i could crack a 13 second :mad:
i ran a
13.854 second
Terminal speed: 102.26mph / 165.15kph
Reaction Time: 0.230
60' - 2.261
330' - 5.983
660' - 9.038
660' Speed - 130.69kph
1000' - 11.643
my car is an r33 with stock turbo (0.8bar of boost), hks-cat back, trust front pipe, stock dump, air filter + cai, fmic, ebc and coilovers. (car is kindof setup for drift, suspension wise, the rear was abit bumpy off the line and down the track)
Now for most of the night i was running a WRX sti, he was getting bettwen 13.1 and 13.3 with 166.10kph terminal speed.
My question is what can i do to drop my time into the mids 13's, i was lauching the car at around 2000-3000rpm and slipping the clutch out (i found 2500rpm was the best place to lauch as min wheelspin)
im not that fuss about dropping the time, as i have a new setup going in soon which should see me get around 350rwhp but im just wondering what could i run with type of terminal speed
thanks michael :)
youl find you were losing time against the WRX in the 60 foot time
( thanxs to has AWD I bet he was getting 1.8 compared to your 2.2), which is why your term speeds are similar but his ET is 0.6/0.7 sec better. You gotta get your 60 foot time down-better launch-more revs(2500 is a soft launch)-so more grip in a 2 wheels drive car so maybe Nittos -maybe better clutch also that you can launch harder against-then you will be looking at 13.4 or 13.5@ 103 mph
Edited by overev1
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
