Just Car Insurance
Flash89
 Share
I am paying $2200 through just car and I'm 21, do they have like a dart board with random quote prices or something?!
I have lost my licence once, but all that does is add $500 to my excess which is $1700
  • Replies 72
yes. everything does because you become a high risk customer everytime something happens...
if i put my boy on there as a secondary driver it doubled because he has written off two cars...
so i didnt put him on or let him drive my car lol
im 19......my car is market valued at 24k, ive had no prev crashed either....i got told it had something to do with the age of my car coz its 17 yo but im not 100% on that one......
and flash 3rd party would probley b better than nutting until u can afford full comp!
ah k... mines only valued at 13k... i want mine cheaper! lol
everything is taken into account. age sex car mods drivers history other listed drivers. i believe it goe on a points scale or soemthing so many point per thing and so many taken off for diffrent things and then you get a score and then your charged to that... (so my boss tells me)
i found shannons the best, and you dont get told how much your car is worth, you can agree on your cars value, wich is good if its heavily modded, i got my car neally doubled in insurance value and was only another 800 a year, i found with just car i notified them of every mod i did wich was about 10-15 at the time, and at the end of the year when i got the renewal with my mod list for my car on it all they had was "hks cam gear" i shouldnt have to chase it up and feel like there trying to cut corners on me, i guess with a stocky it would be fine to use them, but if ya going to mod your car i would use shannons
it must suck to be young for insurance purposes im paying $780 a year for my 93 r32 gtr valued at $30000 with a 34 year old youngest driver thata with torque insurance coz just cars wanted 1400 a year
and i pay monthly with torque :(
Hey i just got a quote from just car insurance with comperhesive. i am 17 and have a R32 GTS-t and it was around $2480. just wondering what you guys think of that price??
Thanks
Looks like you will have to a couple more shifts at dominos
I think im paying about 1400-1500 for my car. thats with every single mod listed aswell. excess is about 2200 for memory... I forget. something stupid though.
And Missy, you definately got that quote pulled from their ass when they did that one.
Weren't female drivers higher risk ? I can't remember if this is true or not ?
no females are lower risk than males.
it says it in the book!
crazy, we dont discriminate sex here at shannons :P
same excess for both males and females.
I have my 1993 R33 GTS-t insured for $23K with a $900 excess. Paying $1500.
got a few extra benefits too that just cars do not offer....
Edited by _8OO5TED_
I'm with HBF got my modded 1995 R33 insured for $17,000.00
$200.00 excess all up $638.00 full comp
I'm 30
only thing is they wont cover my car if i have power fc or boost controler
but will cover after market turbs,my coilies,FMIC and piping,zorst,rims,body kit,everything but the one thing you goto do
got my stagea also with them for $17,000.00
$200.00 excess (thats max nominated on both) $640.00 full comp, my wife also on that policy
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
