I am darg racing my R32 GTR with standard front bar and intercooler this weekend and I wonder if it better to leave the front bar on so you get better aero dynamics and more flow pushed towards the intercooler
or
Take it off and have slightly less weight and more of the intercooler showing. And more air I guess flowing round the engine??
I have to put it on a trailer so Im taking it off anyway but should I put it back on.
Wat are peoples thoughts on this matter??
https://www.sau.com.au/forums/topic/109809-take-front-bar-off-or-leave-it-on/
or
I once took the front bar off my R32 GT-R. There are about a bazillion bolts holding it in place & believe me, by the time you have got half way through removing it you will wish you hadn't ever started. Doing it twice is being a glutton for punishment. Just run it as you brung it - you won't notice the difference either way.
For my 10 cents it would be well worth figuring our how to get it onthe trailer without having to remove the spoiler.
yeah i wouldn't go the cable tie option on a GTR bar. they are quite heavy. on a fibreglass chepo bar for drift it may not be so bad, but not a good idea for circuit or drag.
next time you take the bar off... take the metal bumper bit off two... means that there should be 4 bolts and 4 screws and off she comes. shouldn't take more than 10 mins to take off and refit.
and I would have thought that cable ties are as strong as the screws that hole the bar in place.
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
