Hey Guys,
Back in the day when I bought my R33 (2001) my car had to have a 3rd tier inspection carried out by the RTA prior to getting it rego'ed.
I am looking at buying another skyline soon (never rego'ed in Aus) and sussing out rego etc, according to the RTA site, all i need to do is have a blue slip! Is this right? No 3rd tier inspection req'd?
Any help would be great guys, thanks.
Christian
https://www.sau.com.au/forums/topic/10986-registration/
Christian,
From what I remember you will have to get a blue slip done which will involve you getting a weigh bridge certificate, take that down with your green slip They will issue you with an interim registration sticker and plates and book you in to go get an indentification check at an inspection station.
My memory is a bit sketchy but I dont think I forgot anything.
James
https://www.sau.com.au/forums/topic/10986-registration/#findComment-180199
Prank, when I got mine done, after the bluey, I had to get an RTA inspection done - they check for re-birthing etc. That was a bit of a hassle as you have to supply all import paperwork, application for ADR compliance, compliance engineering, proof of ownership etc -
Dunno if this will apply to you but...
Cheers,
B-Man
https://www.sau.com.au/forums/topic/10986-registration/#findComment-184880
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
