That I bought from someone with the assurance that it was hiflowed, and just needed new seals. For the price I didn't really care whether it was hiflowed or not, basically just wanting to learn more about turbos.
ANYWAY, cutting a long story short, while knocking off the turbine housing, I broke the shaft, which I'm 99% sure is ceramic anyway (given how easily it snapped, it's colouration and the surface finish). Is there even such a thing as a hiflow that only replaces the compressor wheel?
So my question is, how can I remove the compressor wheel? The most obvious option to me is using an easy out tapped into the turbine end of the shaft, but I'm not sure how much the ceramic would let me do that. anyone know of any other possibilities?
cheers
Jeremy
Edited by jezzerrr
Since the turbines dead making the shaft useless all thats any good is the bearing housing and compressor wheel - if its aluminium . You could break up the remains of the turbine wheel and tack weld a cross piece to the flat bit so that it can be held and the compressor nut removed .
Or you could very carefully grind the nut and shaft away till the compressor can be removed though the burr may be a problem .
Its ages since I looked at a Hitachi with a damaged turbine . If enough of the steel section of the shaft protrudes from the bearing housing you may be able to slot it with a saw and use a large plain blade screwdriver in a vise to hold it still while you undo the nut . Two pairs of hands helps .
I'll have another look, I may also be able to get an easy out into the compressor end of the shaft, and undo the nut that way. if that fails, I'll try the other options.
cheers
Edited by jezzerrr
cheers
Dont know of anybody who hi-flows and retains the ceramic rear wheel. Defeats the purpose.
GCG highflow consists of new cartridge and wheels (obviously) uses existing housings but profiles comp cover to suit larger compressor wheel.
yeah that's what I thought. may as well replace the biggest achilles heel while you're in there. I'm still not sure about this compressor wheel though... It's got two paint pen marks on it, one blue, one yellow (from memory), and it also has an N and an 8 cast into the wheel, on opposite sides of the wheel at the blade tip end of the wheel. The wheel also has a few chunks of alloy missing at the inlet end, I'm guessing from the balancing process as there are no scores or marks whatsoever to indicate that they went through the turbo. Given the 8 cast into the bearing housing, I'm fairly sure that it's not a hiflow wheel, but I could be wrong. The pen marks are the wierd thing for me.
Since the turbines dead making the shaft useless all thats any good is the bearing housing and compressor wheel ...
Sell it to someone whos been picking bits of ceramic out of their cat and cursing their bleed valve?
You will need the turbo for the upgrade, dont throw it away or anything, they use your housings.
If you dont want it ill buy it.
Edited by Bezerkly
If its damaged, it will have to be replaced anyway.
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
