Hi all,
My s15 has a bit of a problem. sometimes while driving the car just starts shaking so bad that my car runs so slow on the start, Then if your drive it on 1st gear and let it go to 5000rpm the car suddenly just jumps and works normall again. i had a bit of ideas like, one of my coil pack is not giving a spark and my friends says its the valves coz its bent. if anyone has been through this or has an idea. please let us know.
Thanx all
https://www.sau.com.au/forums/topic/109884-misfiring-or-loosing-rev/
Mmmmmm, well, this is Sau not NS.com. I think you would have a better response there as most people here deal/own with skylines :)
but.....if this thread was in the forced induction section it would get a response that is technical (ish)
just a thort.. have ya check your coil packs (asuming it has them), for cracks or water in them? it can cause them to arc and cause a missfire. happend to me and has also to a few others. if its got water, just dry it and it'll be fine.. if its got a crack in the rubber, u can simply get some good electrical tape and tape it up well.. but not too much that it doesnt fit back in.
also could be a dud spark plug..
just a few ideas
hey mate, sounds similar to what my car is doing, most likely it ya coil packs. i checked all my plugs and they are all in good condition. i think this is caused by them heating up to hot. i have checked all mine and the seem not too look too bad. but still need replacing. im thinking of making up a new loom with plugs for the coil packs as well
i wouldnt think it would b ya valve
Edited by Turbz_13
Yeh i thought that. well im going to check it tonight and hope it turns out well. any thanx all for your response .
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
