  • Replies 46
If the cam timing, duration and lift are the same from one stock R33 to the next then so is the right cam gear dial in.
Timing and perhaps fuelling will need re-adjustment to better suit but, ultimately the effects in the combustion process are identical from one skyline to the next if the exhaust camshaft is the same. I can understand the need to check based on having an RB25 NA with the 4degrees of extra duration or an aftermarket cam.
'Seat of the pants' (feeling the G's) is not very accurate. But having a good ol drive around is what counts.
GTS-t Vspec,
The good thing about the exhaust side is that the slight retard on the exhaust valve is helping the turbo out. You get peak power and torque as a result, at least when the turbo comes on boost which is nice and low on a stocker. I expect about 5kw @ motor more power but, also 4-5kw extra through from begining of the full boost rpm.
We will soon find out if the 1/4 results reflect the idea.
its on!
did it just after lunch. 30min job.
Now all I need to do is set the thing up.
At the moment I am driving around with two 'little notches' of retard. I did this as the HKS piece of paper is a little vague. It says every mark = 2 degrees.
However there are 'big marks' and 'little marks' on the adjustment wheel. Not sure if they are reffering to just the big marks or not. Anyone know?
Even the little I have adjusted seems to have sharpened up the midrange, to the detriment of detonation which I can see from the knock sensor is going to visit the moment I hit 5000+rpm. So later on I'll re-adjust the crank timing to suit.
I think it is the big marks are the degree's but I don't want to say for sure, I thought it said on the actual cam gear itself. Don't drive it too hard until it's properly setup. If I do mine I'll get you to fit it:p
See'ya:burnout:
I been driving around and its more than fine dude. In fact, appart from the timing needing a little backing off, it goes better than before, shows more vacume too for some reason.
No the camgear is neat but, un-informative. It probably is the little marks, at least its good if it is cause I have set the gear up right already and don't have to re-do it.
I could be wrong about the vacume thing, I'll check on the way home.
Miko,
The CAS is dead easy. Putting the Cam gear on with the belt lined up is a son of a bitch (elbow grease).
Broken bolt mate? Those brass bolts are very weak so they don't strip the thread in the soft alloy. Never over tighten any bolt like them they will break on you. The CAS will be fine being held in place by two I'm sure. It should be a peice of cake to drill it out of the alloy bracket.
Yep, apparently you just remove the CAS, the cover (as you did) & you can get to it easily. Remove the broken part of the bolt & put in anothery.
I didn't over tighten the little b$^tard - was just starting to tension & then went loose. Removed the socket & viola, broken bloody bolt:rolleyes:
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
