  • Replies 46
Originally posted by GTS-t VSPEC
You can get perspex ones made for car shows etc, they look really cool, show-off the cam gears without allowing foreign objects in.
See'ya:burnout:
Hmmmm...
who sells em and how much? would look pretty spanky!
I put the cover back on. If you leave it off then you will need to put washers inbetween the CAS and the brakcet it bolts to. Otherwise the CAS will be pushed into the bolts holding the cam wheel on.
The cover is easy to put on and take off. For the sake of greater wear on the belt and the horrible possibillity of droping bolts into the bottom half of the cover (I'm sure a good 3hrs work getting the bastard off and back on) I am leaving the cover 'on'.
If you are worried about heat affecting the CAS then it would be more prudent to ceramic coat the cover. Having said that I doubt the CAS is affected at all by the relatively little heat it cops.
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
