are there any centre muffles/resonators in that system marcus, or just the rear can?
It's got some excuse for a 'resonator' behind the cat... if the pipe is 3.75", the 'resonator' is 4.1" round and about 10" long.
So, more or less just the rear can :P
You can work out how much flow you'll get almost exactly with some simple maths. Multiply the radius (1/2 diameter) by Pi to get the area which equates to how much it'll flow. For example:
 Exhaust		   Area		(x2)
diameter"		  sq"
 2.5			 4.91		9.82
 2.75			5.94	   11.88
 3			   7.07	   14.14
 3.5			 9.62	   19.24
 4			  12.57	   25.14 (ha!)
So as Nxtime showed above, 2x2.5" exhaust has nowhere near the flow of 1x4" pipe.
  • 5 weeks later...
Hey,
I had one custom made by a friend with stainless everything for my R32 GTR. It was around $1500 in materials,
and $400 for 2 x 3" catco stainless cats. He said that he'd do the same thing for someone else for $4k.
Dual 3" off the standard dumps, through cats, to 4" through a 4" resonator and a 4" muffler.
He had to fabricate the resonator and the muffler because we couldn't find anything big enough at the time
and 105dB @ 3700 was too loud for the coppers. It's 95dB @ 3700 now (which is still too loud, but I don't get
pulled over anymore).
Then I lowered it as per the SK GB recommended settings. 355mm/345mm centre-guard (I think!); I think it's now too low.
The resonator touches the ground where there are lumps in the road. I would pull the resonator out and just put a bit
of 4" pipe back there, but...
I'm considering selling it to pay for the new exhaust that will be required for my new T04Z. PM me if you're interested;
I'll take a photo of it (it's off the car at the moment) and put it in the relevant for-sale section. I'm thinking of getting something
in an oval section to get the flow without the clearance issues...
Regards,
Saliya
I believe Autostyle take all their cars to www.bestmufflers.com whom gives a guarantee (to within 5%) of the db output before any work begins. I was talking to the owner of a 500rwkw R32 GTR owner on friday nite whom got his work done their and it didnt appear to go over about 88db.
Hey guys, I'm interested to know, what kind of power are you all looking at putting out with a 3.5 to 4 inch system??
I'm only looking at putting a 3 inch on my 33 GTS-T at the moment as it'll be the car's first major mod, but I am looking to eventually have 300 to 400 rwKW's once I've spent a lot more elsewhere.
I am interested to know as I'm not sure whether to got a cheaper bolt on system for now & then buy a custom 3.5 inch one later when I'm ready. Otherwise if all I need for this kind of power is a 3 inch system, I'll go custom now.
Any input would be appreciated. Cheers
Edited by Electro
i was talking to my exhaust guy, and most aus shops dont really stock 3.5" piping.. its a shame really..
even worse was my old Kakimoto running 3.25 " .. very hard to find a resonator in that size .
going to have to look into a twin 3" system in mine once the rb30 goes in, single now is way too loud, but brand new so i'll try and squeeze another 3" down under there aswell
4 grand for an exhaust system.. haha maybe i should charge people more than wat i do...
either way
4inch mandrel bends = 50 bux each retail is 75 bux from memory?
3 meters of 4inch stainless = i cant member thinking 200 to 250
4inch straight thru cannon = 300 bux (magnaflow i think it is that made mine)
5inch body'd cat 4inch in and out = 300? i think
flanges cost i think 15-20 bux each.. cant remember
so.. roughly 1150 for all materials needed add another 300 for a flat 4inch straight thru muffler for under the car if ya want the 2 mufflers.. than prolly 350-400 to tig weld together and mount.. not all that expensive for a custom 4inch cat back including cat if ya ask me..
making a cat back for a car takes f*ck all time.. longest part of it all would be welding it all if ya ask me..
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
