Max Power about your XR6t I unfortunately work at Adrian Brien Ford, I have seen this happen alot. We had a staff member whos bought a turbo for her husband, it had some clutch problems they wouldn't do it under warranty - this caused a lot of problems around the place as the are so F***ing lazy when it comes to warranty work.(sorry you can probibly tell that I absolutely hate my job and work but this is the truth about warranty work in dealerships they make more money out of the customer than they do Ford)
I hope my warranty works as i had to come home from the cruise early as my clutch is playing up!
Edited by Whiplash
I hate to say it whiplash but the clutch want come under warranty because it is classed as wear and tear I think. I had to replace mine myself $4500 later. :D
wot u put in it a OS geinkin (spelling :S)
and did u do the work your self
i just got Kent brake and clutch to do mine and cost 800or 900 i cant remeber of the top of my head i think 900 for the GTS-4 with a HD xtreme clutch
BOUGHT MY CAR FROM rEDLINE AND I CANT SAY I HAVE HAD ANY PRBS WITH IT.... u DO PAY A LITTLE EXTRA FROM THEM BUT AT ELAST YOU KNOW YOUR GETTING A HALF DECENT CAR (MINE HAD THE AUCTION PAPERS AND STUFF COME ALONG WITH IT.... hAVNT HAD ANY PROBS AT ALL AND WHEN I GOT RAA CHECK THEY FIXED THE STUFF THAT WAS WRONG APART FROM MY REAR SPOILER LIGHT BECAUSE Icbf.
i went into redline a few weeks ago, looking around for my first skyline...however, i've been lurking round for a while checking out prices, and yeah they did seem a little expensive, 2-3k more than other places.
also, you'll be kinda hard pressed to find a GT-R there. the only one i saw was an R32. a lot of 32 and 33 GTS-T's, and most of these were pretty clean.
they're pretty good if you want a supra or 180sx as well, and one thing that i did notice that the brakes on a lot of the cars were very rusty, so that's something you probably should take into consideration when you look to buy...brakes aren't cheap.
new brake pads allways go rusty when i got new pads in my car i would get up and over night there was a rust like residue over my rotors
i dont think that is too much to worry about
A good option is interstate purchases, with RTA inspections and such .. They pick up pretty much everything and more in the way of faults. I saved myself quite a few thousand just by going interstate and driving it back (after taping up the front to prevent stone chips). I could've got it transported but how better to check a car for driving faults than driving it back from Sydney?
I went through http://www.japimports.com.au/ and found Brad Host to be a good, honest dealer. Couldnt be happier with my purchase, he even drove it to the airport for me to pick it up :happy:
They sell aftermarket warranties too for a reasonable price, not that I have had a need but I have called the firm querying. They cover almost everything, clutch, diffs, even exhaust :P
Maybe not relavent to the topic, but a possible other option :(
Interesting option, but do different states have different rules regarding compliance and what is and isn't legal?
For example, if I bought a car that was complied in VIC could it be possible that it is infact illegal in SA due to different laws? I am new to all these rules and regulations so please correct me if I am wrong..
Cheers for the link though!
^^^ yes that is spot on the money my opinion if u dont want to go over the pits @ regency is buy local
but it is a very good option too if u dont mind a visit to regency least it doesnt need full compliance i believe
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
