Hey guys,
Need someone to do me a quick favour. I've noticed that one of my front wheels is off centre relative to the wheel arch (wheen looking directly at the rim). I did some measurments, middle of back wheel to middle of front wheel and got a 10mm discrepency. Found it to be the alignment of the K-Frame (well it's called that on a commodore - has your sway bar and front stabilizer bar connected to it). Fixing it is not a drama at all but I need some measurements from you guys. Can you please measure the distance between the middle of your back rim to the middle of your front rim and post it or PM me please so I know if I need to adjust one side or both. The car still drives and handles fine but now that I've noticed it, I see it very easily and plus it puts excess strain on the sway bar bush o that side.
Thanks heaps in advance Dezz and Randy :turned:
Cheers
https://www.sau.com.au/forums/topic/109935-attn-series-2-owners/
Your not referring to the offset castor on the driverside wheel to allow for australias tapered roads. If thats it...then thats normal if a suspension place has changed the castor bushes or done some sort of alignment on your car...maybe a previous owner? Stops the car from pulling to your left normally.
Thats how i interpreted it. Or have i completely missed what youve said?
I've done a very quick and crude photoshop ob to show what I'm talking about using a pic of my car before it got its wheels. Although this is the same side in both pics, imagine that the 'normal' side, the first photo is the passenger side and the second photo represents the driver side. As I mentioned, the entire K-Frame requires an adjustment. I just need measurements from rim centre to rim centre from a straight series II.
Disregard the height difference, that's just me and 1:20am and St Patricks Day =D
Passenger Side
Driver Side
make sure the person who you get this measurement off doesn't have aftermarket castor rods or bushes!......
just exactly what i was going to say...i've got about 20mm from the front gaurd to my tyre with my castor rods (8deg castor)
dan id be getting under the front to c which arm or rod is bent
this was the same with mine n yet im still to replace it. it will still drive fine due to it being aligned with it being in that position
mine is the radius rod thats bent. $80 from jappo donks to replace
Hey man was wondering when you'd poke your head in =D I've checked all the rods and bars, had it up on stands and the wheel off. The K-Frame needs to come forward 10mm, everything else looks and measures right. I just need some reliable measurements.
Hey guys,
Thanks heaps in advance Dezz and Randy :banana:
Cheers
What's the caster readings?
:P cheers :P
SK: nfi, tell me how to measure them and I'll tell you what they are. As I stated in my blurb, the k-frame appears mis-aligned and that a simple adjustment there will put everything back to where it should be. Unless adjusting castor is going to move the k-krame as well which I can't see how that would occur (but I'm no expert). I can see from the pressure on the sway bar bush that the k-frame needs to come forward and everything would be then be where it should be.
Cheers
Cheers
Caster is best measured on a wheel aligner, as it is a differential measurement. Simply put, the amount of camber when the wheel is turned one way compared to the amount of camber when the wheel is turned the other way (20 degrees is the standard). If you move one side of the front subframe forward you will increase the caster on that side. This will give uneven caster when compared to the other side, the car will pull to one side as a result (the side with the least caster).
Currently you have said the car tracks OK, so that must mean the caster is somewhere near similar, side to side. Move one side of the subframe and that won't be the case. Also moving the front subframe will change the toe settings, moving towards toe out.
My suggestion would be to get the wheel alignment checked before you touch anything, all 4 wheels, camber, caster and toe.
:happy: cheers :P
Edited by Sydneykid
Great, thanks =D
I got 2720mm on the right side and 2710mm on the left so I'll go with 2720 being correct.
SydneyKid: is adjusting castor on the left going to affect this measurement? I might go get all the measurements for an alignment done but have them call me first.
Great, thanks =D
The LHS being short is quite common, it's the side that hits the gutters and the edge of the road surface the most. If you adjust the caster using offset bushes in the radius rods, or by shortening the radius rods, then you will change the wheelbase.
As I posted previously check the caster before you do anything.
:) cheers :(
  • 3 weeks later...
Sorry I didn't see this earlier, Dan!
I can measure up for you if you still want confirmation, but I found today that my castor bushes are completely stuffed, and will need replacing.
I'm going to head up a new post asking for the part numbers, cause searching doesn't give me any joy.
It's all good, I took some detailed measurements and have since fixed the issue. The measurements did NOT add up so the only way to fix the issue was to die grind new holes for the stabilizer bar, which required us to weld on new metal washer and tidy it all up. I've attached a pic showing the end result (just took the pic, the repair a few days old now). I know this sounds very dodgy BUT I had a suspension/alignment specialist on hand to assist and he agreed that this was the best fix without putting the car on a rack and risking bending other components.
For the record the measurements are now PERFECT each side at 2730mm wheel centre to wheel centre. I'll be getting a full balance and alignment after easter as we're putting in my shocks and springs (Bilstiens with King Super Low's for that phat look :))
Just to clarify, we die grinded the original holes back towards the front of the car then welded new metal washers in place (we also sprayed the welds with WD-40 which makes them high tensile apparently). We then touched it up with some primer and a quick hit of black.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
