brand new t3/4 turbo cheap
i got a brand new t3/4 that i fitted onto my r33 but never drove it as my engine needed a rebuild
turbo has a t3 flange so will fit on vl's, skylines, etc
turbo is oil ran and cooled (also im throwing in the braided oil line)
turbo is rated at approx. 450/500hp
located in western melb so any inspection welcome
paid $1000 for the turbo however i am selling it for $600 including the oil line which cost me $100 as i need money urgently for my engine rebuild
pics will be up soon
Interested buyers can also call/sms me on 0402 511 115
Cheers
https://www.sau.com.au/forums/topic/109955-brand-new-t34-turbo-cheap/
Interested, ever been used on any other cars or genuinely new? and shaft play or nicks? Sounds like a home brand as if it were garrett it would be printed on the housing. Check your receipts to see if gcg has written the brand or tech specs on it. Prepared to post to Coffs Harbour NSW? If so how much? Would like to buy asap after pics posted as mine just blew due to the dreaded "foreign object".
turbo is brand new, was bolted up to my car but never used
will post to nsw for wateva the postage price is
pics will be posted very soon as i am having some troubles with my scanner
hey guys,
payment was not received so turbo is still for sale also have dump pipe to suit if interested.
sorry guys not too sure on the brand, when i got it checked out they performance guy said it was similar to a vl t3 but highflowed.
not sure how to put the pics up, tried with image shack but not workin any other ways of gettin the pics up
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
