Hey,
on the way home last night, i was cruising along doing 85km, and all of a sudden the HICAS light came on, it didnt go out so i pulled over, turnoed of car and looked under at it,, (all looks good to me) fuse in engine bay is fine,
so i started the car, and all lights out, then about 4 or 5 seconds after the engine is started it comes on again...
Can anyone help me out here, or suggest whats wrong with it?
any help would be great,
Thanks
https://www.sau.com.au/forums/topic/109957-hicas/
I know the problem... The HICAS is still installed.
Get one of GTRGeoff's lock bars and get rid of it, the lock bar was the best $150 I've spent on my car.
agreed! that's your problem right there! :)
oh, and take the bulb out of the dash when u take off the rack, or it'll stay on and annoy the shit outta you
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2026717
hey Silver_R34_GT-T, is your car still under warranty since you only had it under a year?
HICAS is a real bitch as pretty much no mecanics know that shit in Australia. Ring up Nissan and have a chat, I think that Nissan at Windsor has worked on HICAS before, so I would say give them a go. If not try Fulcrum as they do steering.
Best of luck dude.
Chris
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2029047
thanks for the responses guys, I got in the car this moring, and bam it was on still, then half way to work, it went out and i havent seen it since..
Im hoping maybe it was a bad connection somewhere and it spat itself for a while.. **fingers crossed** maybe its a sign shes on her way out.
Bryn
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2029071
*Hops on bandwagon*
Dude, it's been said before but HICAS is NOT your friend. It also stands for "help I can't actually steer". Dumping it and getting one of GTRGeoff's lock bars in there was one of the best things I did to my 34.
Not a lot of point having a performance car if you don't have any confidence in its handling.
On the whole loose connection thing though, there are a couple of plug-in pin connector things on the motor and sensors attached to rack on the back of your car, maybe give them a wiggle and make sure it's all on tight and the connections are clean.
(pic added - the HICAS unit right before we ripped it off!)
Edited by jmac
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2034613
