If I win Lotto I'm going to fly to Japan and buy that car... Pure perfection
Now theres an idea!
A competition to find pics of the toughest early skyline - this is a good start, and i know of at least one which is on par with this great dr30.
I cant take credit for it - Alfadog first posted these images on the classic z cars forum.
So, lets see what beasts we can dig up!
Edited by The C110
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2043767
That one in the centre looks suspiciously like the off tap blue one that is for sale at Goldie atm :drag:
http://www.skylinesaustralia.com/forums/in...=102340&hl=dr30
Well I'll be. It would seem it is one and the same, This is the original interior shot I have from when it was first imported, which is still pretty much the same. I got these photos from an Importer in Adelaide when it first came in a few years back. Cool car.
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2051277
R30 4 door wagon..... LOL
Wow great turnout :P
That tungsten C10 would have to be just about THE toughest i have ever seen. Nice R30's, that wagon's great, wish there were some nicely modified ones over here - theyre definitey something different. That group shot of DR30's is fantastic, however, i really dont understand the thinking behind those despicable 'box' type ducts on the bonnet of the front two - their lines are completely ruined!
Lachlan, have you ever seen any well modified c110 WAGONS before? I think they'd look quite cool, and be very different. Anyway, heres a couple more:
ps- i know theres a 510 in there but its super tough
Edited by The C110
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2058397
Nice - the blue "666" race car is brutal.
In regards to C110 wagons, the most modified I've seen are that blue one and this very mild one (attached). I agree they have potential, but I seem to recall they were only SWB (happy to be shown otherwise!) so it would be kind of silly. How about a wagon with GT-R flares, and an SR20DET? Now that would be different...
Edited by Alfadog
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2058451
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
