If I win Lotto I'm going to fly to Japan and buy that car... Pure perfection
Now theres an idea!
A competition to find pics of the toughest early skyline - this is a good start, and i know of at least one which is on par with this great dr30.
I cant take credit for it - Alfadog first posted these images on the classic z cars forum.
So, lets see what beasts we can dig up!
Edited by The C110
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2043767
That one in the centre looks suspiciously like the off tap blue one that is for sale at Goldie atm :drag:
http://www.skylinesaustralia.com/forums/in...=102340&hl=dr30
Well I'll be. It would seem it is one and the same, This is the original interior shot I have from when it was first imported, which is still pretty much the same. I got these photos from an Importer in Adelaide when it first came in a few years back. Cool car.
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2051277
R30 4 door wagon..... LOL
Wow great turnout :P
That tungsten C10 would have to be just about THE toughest i have ever seen. Nice R30's, that wagon's great, wish there were some nicely modified ones over here - theyre definitey something different. That group shot of DR30's is fantastic, however, i really dont understand the thinking behind those despicable 'box' type ducts on the bonnet of the front two - their lines are completely ruined!
Lachlan, have you ever seen any well modified c110 WAGONS before? I think they'd look quite cool, and be very different. Anyway, heres a couple more:
ps- i know theres a 510 in there but its super tough
Edited by The C110
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2058397
Nice - the blue "666" race car is brutal.
In regards to C110 wagons, the most modified I've seen are that blue one and this very mild one (attached). I agree they have potential, but I seem to recall they were only SWB (happy to be shown otherwise!) so it would be kind of silly. How about a wagon with GT-R flares, and an SR20DET? Now that would be different...
Edited by Alfadog
https://www.sau.com.au/forums/topic/109960-splumpf/#findComment-2058451
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
