  • Replies 77
Posted Images
I ran 275/40/17" Nitto Drag Radials on a 17x8" rim and they were fine.
I run the 255/50/16" MT ET Streets on a 16x7.5 although a 16x8" (R32 GTR rim etc) or 16x7" rim will be fine too.
Adrian
If we get enough buyers, ill see what we can get a set for, may not be as cheap as the smaller tyres, but still should be discounted.
Ok guys, got some pricing.
235/60/15 $235.00ea
255/50/16 $250.00ea
275/40/17 $275.00ea
This is depending on the amount we buy, im buying one set of each for the shop so we need at least 7 more buyers. these are as cheap as youll find, these tyres retail usually for $270, $290 & $317ea.
Am going to WSID weather permitting on wednesday night so Mona can try a set for a comparison. Will post results, after that ill be ready to order. Can PM me if interested, and will arrange electronic payment.
i can bring tyres to WSID the following week or pick them up from shop.
Would we be able to get a price on these? and whats the recommended rim width for 275 tyres? will they fit 9" wide rims or will they require bigger?
MT recommended rim width for 275/40/17 is 9".
235/60/15 $235.00ea
255/50/16 $250.00ea
275/40/17 $275.00ea
I have about 20 X 17" wheels that are suitable, but no 16" wheels wide enough.
So the extra $25 is not an issue, cheaper than buying wheels.
I just have to check the clearances on the 2 cars.
So I will either get a pair of 255/50/16's or 275/40/17's.
:P cheers :)
:P cheers :D
Cool, pretty sure Adrian (2rismo) has run the 17 under his 33. Ill take all the orders on thursday after the drags, and get them all down.
The 275/40/17's 'just' fit on the bum of my 33 gts. I may have had a very flukey offset though....
SK, you can pick up stock 300ZX rims for about $30ea so to save headaches, I'd get a pair of them and buy the 255/16's with the greater sidewall.
Just a thought.
Adrian
surely 255 wont fit on stock 6.5" rims, 225s are allready bulging out of the side. Im pretty sure the stock 16" were meant for 205 tyres.
Anyway, Im down for a pair of 275/40/17 if this goes ahead.
Any chance of interstate postage and how much? or do we have to arrange pick up in sydney was it?
I know this is probably not recommended, but are these legal to use on the street?
Yes they are one hundred percent street legal. are a soft compound though, and have decent sidewall, look tough on the street.
Just a thought.
Adrian
Thanks Adrian, I do have set of Stagea 16" wheels, same size as R33GTST. I was thinking more along the lines of R32GTR rims as they are 8".
The taller sidewall is a thought, have you compared the 255/50/16's and the 275/40/17's times? Is there a noticeable difference? It's a width versus sidewall comparison, which gives the best result.
I have a pair of ugly 17 X 9" with a serious 45 mm offset, on those wheels the 275's would have no problems outwards, maybe inwards would be an issue though. That's what I have to measure.
:happy: cheers :P
Guest
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
