well there is one next Sat at Oran Park.....but it looks like you aren't that local :)
If you want to be out with some Zed's ( boats ) some fast boats though , our next track day 17th September at Wakefield.
  • Replies 90
John,
Im getting closer and only using those "old slick" that you called crap!
I guess the real killer punch will be when the GTS track b!tch comes and eats you up!
Im coming to drop some stuff off today, see you then! Good times again, but yesterday was by far my best times ever.
John,
Good, bring it on, and do you think I will be standing still? We have plans.
Yes you now see slicks are not aways better and Michelan are much better than Yoko slicks and heat cycle much better. Yep when I was running these slicks everyone was saying " Yeah but you are runnin gslciks and not fair and bla bla" Now they are crap.
Bit of dirt on track on the right hander after the bridge I found out the drifters were there on the Friday night chucking it around.
I think the standout driver of the day from the SAU camp was Adam (abo) in the R34 GTT.
Automatic, semi slicks, R34GTT (not exactly the best suited model of skyline for circuit work) and less experience than both of you resulting in a 1:24.37 and only 1.7sec behind Pauls R34 GTR, thats tops!
No Doubt Abo does a fantastic job in that car, it has good suspension, good tyres and there is only about 5-10meters difference between us down the straight. Last time we were at wakefild Abo was faster then me by the same amount
Thanks for the pressure Duncan,,,it's all good though I'm up for it. Time to put the real diff in, a new clutch and a quick dyno job.
BUT there is another,,,,Mr Bullivant has done a 1.22.62. Yes Ian I am a snoop.
Neil.
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
