Hey Guys,
I just bought myself an 95 R33 GTS-T. and I was wondering how much power do these cars have stock (est),
I have bought and installed and ARC intercooler and Blitz Bov and Air inducts, I dont have any boost controllers or guages, how do I know how much boost its running and what is stock boost?
Sorry if Im asking any stupid questions, its my first Turbo car and Ive always owned V8's so I havn't had any dealings with Turbos.
Your help would be very much appreciated.
https://www.sau.com.au/forums/topic/109979-new-skyline-owner/
Dead stock about 155rwkw.
You do have a boost gauge! Its in the instrument cluster (the +7/-7 gauge).
Stock boost is 5psi at low stage and 8psi at high stage.
See:
http://www.skylinesaustralia.com/forums/in...showtopic=42895
depends what dyno but I reckon more like 130-135rwkw. Remember 187 or 184 flywheel kw. Budget on 25-30% loss through drivetrain..
The stock comp is crap if you raise boost or add intercooler. Factor in Powerfc or at a minimum an AFM bender (SAFC) and you will get the gain from the mods..otherwise don't bother with any more than a couple of psi boost increase and exhaust. At 9-10psi you are at the border of rich and retard so may be dont even bother..
Edited by benl1981
I had one 3 years ago and it made 132rwkw with cat back exhaust.Otherwise stock.
Well 140rwkw is a 25% loss through drivetrain so I wouldn't expect any better than that.
All depends on the dyno but 135rwkw on a REALISTIC dyno is about the figure.
In a motor mag the astra turbo dynod at 100wkw when it has 147kw, sportivo about 88kw (flywheel 141kw).
I would expect you would lose around 50kw or more...
Edited by benl1981
See:
isn't 150rwkw more likely a stock series 2 figure? I reckon more like 135-140 stock.
Series 1 and 2 will have about the same rwkw. They both have same engine management and engines. Same turbo as well (some may have nylon compressor wheel for quicker spool but no difference in size)..only difference is the coils, series 2 have inbuilt ignitors.
All depends on condition of engine..
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
