I know i am, grandstand tickets, Barry Sheene Pit Straight (up the end in N i think).
So who else is heading along from on here?
Im missing out this year, unfortunately Ive got a bucks show on that arvo - with topless waitress's serving unlimited Coopers & spirits, and includes the Barbie Babes lesbo show..... should be 'interesting'
https://www.sau.com.au/forums/topic/109981-clipsal-500/#findComment-2026828
I'll be there Ash, took Thur and Fri off work, but won't be going Sat due to a family doo........but will be there Sunday for sure, with the old boy who's coming over from WA!
Mate won tickets in Superkarts which are on the Pit straight grandstand also!
Mate is hopefully racing a Aussie Car also, just waiting to see if cash is coming thru for it, and if it does i will be helping him out on the Thurs and Fri!
https://www.sau.com.au/forums/topic/109981-clipsal-500/#findComment-2027170
I'm going all four days
Got seats in the Pit straight, have also got a team pass through my mate John Bowe :) . Will be spending the Thurs and Friday in with them and the rest of the time in my seat. always keen on meeting up with people.
https://www.sau.com.au/forums/topic/109981-clipsal-500/#findComment-2028362
yep we will be there for the 4 days as per usual. Met up with a few of you blokes last year for a beer right near the fashion parade stage benhind Pit Straight. Will give those whose numbers I know to catch up for a beer. Anyone wants my mobile number PM me.
https://www.sau.com.au/forums/topic/109981-clipsal-500/#findComment-2031756
