Urgent Gtr Stolen, Enroute To Brisbane Tonight, Blue R33 Gtr 867 Ivl
MFC05
 Share
As per topic.
A blue R33 GTR with black bonnet was stolen in Ocean Shores (northern NSW) yesterday morning and was seen several times in area today and around Murwillambah.
According to reliable sources it is headed to Caboolture this evening (or maybe) tommorrow to be stripped and crushed.
Number plates are 867IVL
The guy who has taken it hasn't got much regard for other peoples safety and is not really trying to hide the fact.
If you spot it please call the police immediately.
These guys have stolen quite a few Nissans recently so it is in all our best interest to help out.
Chris
0410 468102
As per topic.
Chris
0410 468102
What a$$h0les!!!!!!!!!!!
This is becoming ridiculous!!
I am almost at the point of actually looking my car to the house with a big chain and padlock. In addition to the Security System and only sleeping 10 metres from the car.
which is exactly why mine are locked in a hidden workshop with maximum security measures and i live on site-so if any prick tries to steal anything well they will meet my 2 good friends-Smith and Wesson!!!!
Edited by overev1
Didnt stop the fcukers from taking Dan's R34, he was sleeping within 10mtrs of his.
Car thiefs should be shot, simple, effective, humane.
I nearly had a heart attack when I saw a Blue R33 with a black bonnett at Indooroopilly shopping center tonight - the numberplate was incredibly similar too - The front end looked like it was a bit dodgy though, and the numberplate didnt match (this one was 769 INV)
Sorry dude!
Sorry dude!
You should have gone back and checked it out as it is very possible that they have changed the plates and parked it in the shopping centre till the heat dies down. I would go back and see if its there.
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
