I know its not a replacement board, but i reckon it would be cool if we changed it from mysfits to SDU-AU......... i know you might not agree, but then if we do this can be a central meetin spot for discussions on it that the nz'ers can 'close due to technical reasons'
i dunno, am i outta line here? I dont think i am......
https://www.sau.com.au/forums/topic/11-logo/#findComment-164
MatBoy,
I have no problem with that and I will change the name ONCE everything has been sorted out. A few of us have been discussing SDU-AU behind the scenes, once we have a name etc, it will be done! :P
Christian.
https://www.sau.com.au/forums/topic/11-logo/#findComment-165
Well I feel hurt by SDU, so I think you should tie with the yet to be formed FAADBCCFAWNATBH
I think leave the anti-social-know-all-type-tech-but-not-really-bum-headz to themselves.
Even the name Mysfit sounds like a fun group. Can I join?
https://www.sau.com.au/forums/topic/11-logo/#findComment-173
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
