i have a a r34 rb26 in need of a rebuild and need help!!
the car it is in is a ex D1GP car and is obviously used for drift.
it has run a bearing (1 or more) possibly due to oil surge
anyway it is now due for a rebuild, we were atleast going to go
pistons, rings, rods, n1 oil pump, trust extension kit, is highly likely we will need a new crank
as we realised what was happening quite late ( can't hear anything over the 3 fuel pumps)
we were going to go with the first stage hks 2.8l kit but evidently the block wouldn't like it
and we would need an N1 item, so that scraps that idea also we were told that we may aswell
throw the engne away as bits of bearing would be scattered throughtout the engine (i thought a good flush and tidy up/porting would be sweat!)
any way what options do i have with the crank, scatered metal in the engine, etc.
ps we are looking for around 600-700hp rear wheels (we have all the externals to handle that and more!)
cheers
https://www.sau.com.au/forums/topic/110005-r34-rb26-rebuild-time-drift-spec/
yeah 450-500kw drifter
it is nuts already but hey can never have enough and since it needs a rebuild anyway
it did a team event with kuroi at an option 2 event in 2004 i think,
anyway, do i need a n1 block for 450-500kw? with a stage 1 hks 2.8l kit?
what are my other options with the crank what is good out there and what $$
any of you guys that has had an rb26 expire in the same way have any problems
with debris through the engine?
ohh and yes it is a four door
cheers guys
might even post a pic of one of the laps before it let go
cheers guys
u got jun 2.7L billet, full counterweight crank, tomei 2.8L (not full counterwieght i dont think) and the hks 2.8L crank, though there a few different hks cranks in the 2.8L depending on power. and n1 block is only 3K i was told which if i knew when i did mine id be using one str8 up, not worth risking on a normal block when they are sooo cheap :down: plenty of options around, try searching the site for stroker kits as their was a large thread on it a fair while ago now discussing all the options :(
show us some pics :( is it a skyline or a chaser going by the jzx (rb26 powered) as your listed car?
at the time it blew it had 334kw rear wheels and 1100nm of torque but that was detuned running pump gas.
the head has all the bits (may be looking at new cams if debris got up there though).
Was told that the r34 block was basically similar to the n1 in design ( with extra ribing for greater torsional strength stopping cracking in the block at hi rpm) , would be going for the first stage
2.8l kit the second and third is a bit overthe top
yeah its a mark 2 toyota powered by a r34 rb26
350rwkw is a much smarter, cheap and more reliable approach than 500rwkw.
plus drifting is more about car setup than power.
personally stick under the 400rwkw marker, far better response and throttle control can be achieved. And thats what you need correct?
yeah decided 500kw is a bit over the top but would like 400kw, the power hits in an awkward time for me anyway and was going with the stage one 2.8 kit (highest compression version) to move the torque down in the range a little bit with a bit of response (would this be the case?)
as for the power in drifters issue have you seen kuroi's 900ps onevia powered by rb26, but yeah i do agree
does any one know if the r34 block is similar to the n1 in design ( with extra ribing for greater torsional strength stopping cracking in the block at hi rpm)?
btw the track is in NZ pukekohe infact (mega entry speeds into that sweeper!)
my work brought in a 33 gtst x Garage Aqua track car from Japan with r34 n1 crank, rods and oversized pistons stroked the 25 to a 2.7lt its fitted with a RX6 made 355rwkw on flat out mode i.e 1.8 bar
Its super responsive span the semi slicks up in third without any problems on 1.2 bar.
the guy that bought it drifts it on 1 to 1.2 bar so just on 280 - 300rwkw plenty of power
R34GTR (RB26DETT) block measures up exactly the same as an R32GTR N1 block. Personally I think the N1 block is under utilised in a 450 rwkw application, a standard block will handle that easily.
My 20 cents…….
Dismantle the R34GTR RB26DETT, clean it up and work out exactly what it is that you need to replace. Then get on with the rebuild stick a standard crank, some good rods, bearings and pistons in it and control the oil temperature and flow properly. It will handle the power you want easily and with a decently ported cylinder head and 9 to 1 compression ratio it will have all the response you need. Ceramic coat the piston crowns, the combustion chambers and the exhaust ports for the superior temperature control and a further improvement in response.
:P cheers :)
thanks Sydneykid, i thought the 34 block was similar and could handle over what we wanted, will
look into your suggestions engines in the process of coming out at the mo.
one of the strong reasons we were looking at the hks kit is that it would only be alittle more (not much at all) to get it than get all the bits and a good stock crank :P
(over here anyway)
still cant belive it had oil surge after competeing in d1gp and other japanese events
only thing i can think of is they ran it over full?
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 🤣, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
