I've just purchased a cast for my RB25DET in a 180SX setup. (not on the road yet)
The manifold is designed for IHI/Apexi Turbo's and a Greddy Type R External style wastegate.
I have a GCG Garrett GT30/40R (.63AR) Turbo, and a Tial 38/40 External Wastegate though, and need some assistance with adaptor flanges.
Can anyone advise where i could buy such adaptors?
Is it likely that i'll have to buy a 38mm tial adaptor, and a (??mm) Greddy Type R Adaptor and have them welded together to make it join up?
Thanks.
Edited by silman
https://www.sau.com.au/forums/topic/110007-exhaust-manifold-adaptor-flanges/
In a nut shell yes. Though you can get your exhaust shop to make up custom flanges for you to if your in a bind and cant find any off the shelf
As the manifold is cast it isn't as easy as lopping off the flange and welding on a new one.
It does look like the wastegate flange already has an adapter on it as well which you should probably remove to tidy the whole thing up a bit.
Where you will benefit though is by having the adapter you can cutsom make it to fit the wastegate pretty much where ever you want to mount it.
And atleast you know the manifold won't crack.
most tials come with flanges when you get them, an exhaust shop can get a laser cut flange done custom pretty easy (for the manifold end of the wastegate feed - had to do that for exhaust flange on my turbo) then weld up a pipe to position the wastegate lower in the engine bay.. to keep some of the heat away from other gear
prob quicker and easier to just get them to do the mod on the turbo feed too.
i would have thought a genunie apexi one would have been better designed than that
Are you really in the moderators group?
what's so wrong about this manifold?
keep in mind the flange sits back to keep the centre of gravity towards the middle of the car. The wastegate points straight down to avoid heat issues. What exactly is so bad about it?
yeah i am in the moderators group, how come?
nah sorry i should have re-said what i meant
i expected tuned lenght tubular style instead of log style
no real reason why, i just expected that i guess
to brutally honest, your first reply was not helpfull, and didn't answer any of the questions i asked and either has your second. I'd expect more from a moderator.
thanks to the rest who replied, i'm going to look at selling the tial and purchasing an hks w'gate.
As for the turbo, i rang gcg today to ask if they have any experience with using an apexi/ihi turbine housing on any of there gt range turbo's to which the answer was no. Will have a custom flange built up to retain the current turbine housing i have.
right and so because im a moderator im expected to instantly answer everyone's questions?
i dont think thats the case at all. its an open discussion forum for exactly that, an open discussion. i never said the product was good or bad, i just commented on it. sure it didnt help. it's not like this place is an online helpdesk system, its an online discussion board.
sorry if you were given the wrong impression.
just noticed that this manifold would fit both RB26 and RB25 ..
wouldn't see it as being as efficient as a tube style, and the wastegate feed is in an opposite direction to the gas flow..
but still would beat any modified std log manifold with external gate flange welded on.
interested to see how much room you have for the dump pipe too, with the turbo sitting so far back, will be tight to the firewall in a sylvia/180 i would think.
check your prices for HKS wg's too, very pricey, might be cheaper to get the flange made than swap to HKS unit. dont go the cheap copy, they suck balls
Yep, also fits RB20. I agree it wouldn't be as efficient, but i weighed that up against not having to worry about a cracking manifold. The dump pipe will be a very tight fit indeed. I buy everything from Greenline. Yes definitely wouldn't risk my setup on a cheapy hks copy.
I didn't comment on the turbo inlet flange before, but it looks to be common t3 sized so you shouldn't have an issue.
You can always wander into gcg or garrett with the manifold and ask to trial fit a t3 flanged turbo.
check the centre to centre spacing of the studs, T3 is 86mm/43.5mm (long/short side), T2 is 73/38.5.
    • R32 pics Not sure if you can upload pics directly, but i've added them through an imgur link above.
    • There’s a possibility that Infinity G35x front hubs may be compatible, but it depends on the exact fitment. Sometimes, parts like hub and bearing assemblies from different models can work if the bolt patterns, bearing sizes, and axle specifications match, but the G35x hubs typically have a different design. It's worth checking detailed specs (like the number of bolt holes, size of the axle shaft, and bearing diameter) to compare, as Rock Auto does list some parts that cross over across different models. If you're going for a pre-pressed hub and bearing unit, that could be a good option. These units are usually easier to install, as the bearing and hub come pre-assembled, but you’ll still need to verify fitment, especially the outer diameter of the hub and bearing dimensions.
    • Love the input man! Defo gonna check it out
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
