Electrically operated valves.
I’ve been waiting for these since I was a kid, and that’s along time ago.
So what’s the hold up? Formula 1 engineers had a toy with the idea and Mercedes actually has an engine running.
The enormous tuning options are only limited by our imagination.
Just a few:
No cam shafts, timing chains, lifters, rockers etc, etc.
Engine starts decompressed, builds oil pressure then the ecu kicks in some cylinders.
Valve lift, duration and timing all adjustable via the ecu.
Vary the engine capacity by partially filling cylinders to offer a smaller capacity for light load, idle situations.
Completely drop off any cylinder at any time, the mind boggles at some crazy firing orders.
Real engine braking, make the Jake brakes on the Kenworths look twice.
With the fanfare of GM’s “new” olloytec engine and Ford strapping a turbo on their twin cam head, all technology at least 10 years old, where are all the lateral thinkers?
https://www.sau.com.au/forums/topic/110009-electrically-operated-valves/
This would just give manufacturers another reason to f*ck car modifiers in the arse. Notice that it is starting to get a lot harder to modify cars these days because of more and more electrically enhanced products?
An example of this was when the XR6 turbo came out. There were/are measures to prevent turning the boost up too much. It is a complicated issue to fix, which most people have got around by engine management computer modifcations.
You can get around these measures by aftermarket development, but as manufactures get more clued up as to how to protect their development, a lot more work needs to be done by the aftermarket companies to catch up. Hense the price of developing products to overwrite the manufactures settings will be passed onto the consumer.
Edited by Thunderbolt
Would the gains over a well designed multivalve, variable valve timing, variable valve lift engine make the enormous increase in development costs worthwhile? Imagine how much software development would need to go into programming such a thing?
Has been and is still being tested but it needs a Power system much greater than 12 volts.
More like a 48 Volt system and the Current draw on the much larger required alternator to keep the system running puts a massive drain on the engine negating the power penefits gained by not direct driving the Valve train from the Crankshaft.
Works in theory but expense and lack of real world practicality will see it delayed until other problems are overcome.
The valves use a solenoid actuation but with much more control than a conventional on off solenoid.
F1 already use pneumatically actuated valves because a normal cam shaft wouldn't be able to keep up as I understand.
The big determining factor is cost.
The bean counters are the ones who run companies these days.
Doesn't matter if it's a quasiturbine, rotary, 2-stroke, 4-stroke, they all have a valve or port of some sort and that's one of the first areas that gets modified when you're trying for more power.
Incidentally there are a few patents pending and of course they don't use massive voltages, solenoids etc. Mostly electro/hydraulic and are capable of operating well within the range of conventional engine RPM's.
As for developmental costs, have any of you seen how complicated a sleeve valve is? Check out a Bristol Centaurus.
  • 3 months later...
It's not the camshaft that can't keep up, it's the speed at which the valves have to operate that is the problem. They open and close so fast you get valve float. To stop this you have to use stronger valves springs or dual springs. This becomes a game of diminishing returns as revs rise so do spring resistance , sapping power to open and close the stiffer springs ,etc Ducati and earlier Mercedes use Desmodromic valve operation. This system doesn't use valve springs but levers off the camshaft to positively open and close the valves. Pneumatic valves just use air or N2 for springs
Rota whatta whatta?
What are these fandangled things you speak of?
:P
The next BIG step will be rotary valves in the everyday engine. This kind of thing makes camshafts and valves obsolete. Once the bugs are ironed out that is.
just google "rotary valve engines" for some good examples.
rotary valves on one of these.
(just trying to up the ante. Don't care much for counter rotation, but more power al all rpm + a higher rev limit...)
and although the how stuff works article implies it, I don't think there has been a working prototype of an internal combustion quasiturbine engine.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
