Hi guys been having problem with my R32 GTST lately, just some info on it first, stock turbo, gtr front mount, turbosmart bleed valve, pod filter, 3 inch turbo back exhaust, apexi bov.
The problem im having is very intermittent sometimes I can drive with no problems for a whole day ,ive only noticed it happening when the cars warm but sometimes when im around 2000rpm in any gear the car just loses all power, I can put my foot flat to the floor and nothing will happen and then all of a sudden it will jump to 3000rpm then no higher, sometimes after this happens I wait a few seconds then its fine other times it will then stall, when I try to restart the car it is very hard to start and needs me to rev it as its cranking over, sometimes once its restarted it will work fine again and sometimes the whole process will repeat itself, it can happen any time even while cruising along in say 4th the revs will just get stuck around 3k.
Ive also noticed since this problem started the car is idling quite low sometimes around 400rpm.
Any suggestions what it could be as its doing my head in,
thanks guys.
Hey Guys,
Dave & I cleaned the AFM on his car last night. So far it seems a bit better but time will tell as it hasn't been taken for a good drive yet. Will let you know how that goes. If you have any further suggestions or comments let us know!
FYI; It's running 11psi.
Ryan
Edited by d0p3y
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
