Hey all im new to this forum,
Anyway my cuzin has r34 gtt, now im wondering what psi/pounds to they run stock!
on the guage it almost touches 1 kgcm, now i recently foung out that 1 kgcm squared translates to roughly 14 psi, so if it almost touches it then it would be running around 12 pounds.
Everyone told us includng the imopter dealer that they run 7-8 pounds.
then it sould be hitting around the middle of the guage bw 0 and 1 (0.5)
sorry to confuse
btw he has catbak & shitty filter.
so did the import deaer sell him the car boosted or....
Cheers.
Edited by KLRREX
https://www.sau.com.au/forums/topic/110027-r34-gtt-boost-range/
Mine runs 6psi until about 5,000rpm then goes to 7psi from there to redline/cutout, read with an aftermarket Autometer boost gague.
On a really really really cold Canberra winter night I saw it hit 8psi once, whoa look the f**k out :)
The standard gauge isn't the most accurate, but with a Cat-Back and Filter he should really only be seeing a Max of 3/4 of the gauge (about 0.7-0.8 kg/cm2)
Anymore means he could have a downpipe too or a simple bleed valave boost controller hidden in the engine bay.
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
