I was wondering if c spanners are all the same. Ive got cusco suspensions and 1 of my sides droped a cm so i need to adjust it. Do i just get any c spanner to do the job?
Can i do the adjusting some other way?
And also how much are c spanners for brand new and second hand?
Thanks for the help guys!
https://www.sau.com.au/forums/topic/110036-are-c-spanners-all-the-same/
And if you have any fabrication skills you can make your own..just measure the width and length of the hex faces and draw it out or just scribe it onto a piece of steel and cut it out and weld on a handle or just make it outta one solid (billet) piece. Cost ya nothing if you have tools and some scrap steel/ally or a mate who has access to those things.
Then you can feel all manly cause you did it yourself and you can show off your engineering prowess. :down: I would....but i use the drift and knocko trick as well.... :( (slacker)
Last C spanners i saw for sale were at jambo for one it was 50bux...annodised ally....so 100 bux for the set...abit exxy...but i think everything is these days.
Edited by r33_racer
garage-13.com sell c'spanners for tien suspension, which is more or less the same as any...
you can also get them at most places who sell bearings (cbc bearings etc.) but tend to be a bit more expensive than the tien ones.
though... i just use the screwdriver and hammer trick!
Bearings shops (CBC and NBC) sell C spanners in several sizes. Just measure the diameter of the lower spring seat and the locking collar (if it has one).
:happy: cheers :P
PS; why has it dropped a cm on one side? That's the important question.
I dropped a cm after a lil spin out accident i had. Probably put a lot of pressure on the suspension and a lil knock with the tyre and curb.
I see c spanners for sale on ebay for around the $35 mark delivered, no brand and i think they are for adjusting bikes. Do i just measure my suspension size in order to get the right one?
Edited by cjlancer
I got an Ohlins C Spanner from a motorbike shop for $19.95.
Fits my Apexi N1 Coilovers beautifully!
Motorbike shop is the way to go, IMO they are less likely to rip you off!
...to answer your question, no they arent all the same, but they are a fairly generic size, and if you buy one a little bit too big or too small it will still work fine..
Edited by Primordial
  • 3 years later...
hi guys, just bought some c spanners today from bilstein at princess highway for 33 bucks a pair. im using them for my tein hr.
i looked everywhere and the best price i got was like 80buks from suspension wholesalers at blacktown and penrith...
stuff that there just bloody c spanners.... the ones i got from bilstein fits pretty good so if u need any i would recommend taking
your coilover to them and try a pair out... dont get ripped off
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
