  • Replies 74
Posted Images
im kinda sceptical on ur time, as nos generally removes 2 seconds
i think i saved the replay no nos fitted at all to the car.
with nos you should be able to take off more than
2 seconds on such a large track
*edit, typo*
I did the ring in 5:45 something in the R32 GTR Calsonic... Fully worked with nos and a long 5th. No spins, and a generally good clean run. I had holidays for 4 weeks :)
*edit, typo*
Got a split?
...and maybe post a pic of the screen for these 'ultra' fast times :dry:
  • 3 weeks later...
'97 R33 GTR Vspec
8:37.421
Stock w/ sports med tyres
Slides more than the 32 i reckon so i think i could better my R32 time easy.
BTW im only doing 2 laps with each car as it not the shortest track in the game lol. first is to get the feel of the track with the car and then i see if i can beat that one.
Edited by Freddy Kruger
thats exactly what I do, you need to set a time and a ghost car to beat :D
'99 R34 GTR Vspec
8:24.817
i rate the r34 :ermm: definetly holds the road better than the r33. plus it was red so it gained an unfair advantage with speed :sick:
might do a 350z next or the gtr proto? dunno...
Modified Mines R34 GTR
6:54.775
i could get quicker i reckon with changing the gears and suspension as it topped out at 348kmh on the straight and slid like a mule round some corners...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
