The Libs or Labour?
20 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 46
I was talking about the kind of stuff shown on shows like "A current Affair", doing 150 plus kmh, street racing, donuts in main intersections etc...
If you need to stop in a hurry in that instance, what are you going to do? (Even if you have wilwood calipers and vented rotors)
My kids nearly get knocked over on their way to school at least once a month (Live across the road from the school), so I fear for their lives.... which is fair enough i think..
And the comments were made in relation to which party they voted for, not about if the cop was having a bad day... If thats the way it works, then no, I don't agree with cars being impounded cause someone dosen't like the look of you....
Touche'... I was called on it, and I lost.
(BTW:The "look out nanna" call wasn't made by me.)
I won't pull the video down.... don't see the point... but if a mod wants to delete it, fine.
Sometimes I go off at the smallest things, for some reason, I snapped at this.....
I expected to get flamed, and here we are...
Carry on...
(Yes, I admit I was showing off for a video..... you wouldn't?)
Edited by PimpnQ45
I am totally confused by this thread, can someone please explain it to me
I know that God didn't make Adam & Steve
But who made gays?
Did God develope IVF?
Gay men and IVF, how does that work??? Do we have the technology???
Amen Brother !
um remeber Mr Mom with arnie :D i think it can be done :D :S
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
