  • Replies 172
Off topic
But i have the Lenso GT-05 in Shadow Chrome and they look hot on a silver/gunmetal skyline, reckon they would look awesome on black. BTW i have also never seen the GT-05 on a car in a magazine or even on the lenso website, let alone on a car in the street.
cheers
Evil
I think it does, once i saw a 33 gtst with BA XR6 rims so should fit in 33, why not buy steel rims from Territory as they are same size as XR6 rims.
Just a tought.
Cheers
Grant
  • 6 months later...
Some upgrades have been done to my car including:
Locked diff
Cushion brass button xtreme (crap) clutch
Greddy Profec B Spec 2
Metal intake pipe
Exhaust modification
Series 2 OEM bonnet (needs to be sprayed)
CREATD Motorsports have been very helpful with answering all my questions and helping me out with fabricating the custom exhaust for me, they are also looking forward to me punching out some decent power in the next couple months. Rob is the man for any r33 gtst!!
Future mods:
Spray the damn bonnet
TOP SECRET front bumper
D-Spec (URAS) rims in black
Stage 3 highflow (Slide)
Apexi Power FC + Z32 afm
The aim is around 250 - 260 rwkw, and all that will be used for street and drift :) Car now makes 209.5 rwkw on the msc performance dyno
Creatd motorsports will also be doing my tuning and giving me advice when needed. Big thanks to Rob & Daniel
Edited by LTHLRB
How you gettin 209.5kw without any ecu management??
you said furture mods-- power fc.. So im guessing you dont have it yet..
Or you got another ecu in there atm?
One more question. Hows that Profec boost controller?? Does it hold boost well? Worth the money??
yep worth the money, i baught it for 470, you can find them cheaper now.
I am getting 209kw without any form of aftermarket ecu or injectors.
I am getting pfc to replace the std box of poo.
yeah i am happy with the time, 1st was missing traction somewhere... but i will be back out with alot more power than the power i have now. And that was on 225/50/16 at around 13psi in the tyres.
I am not the best driver out there, i want to run the 12 with me driving. Currently its not bad for an l plater :) haha
mate those lensos are mental. What sizes?
i have a question to people out there, how are your bottem ends going with 250 and over with hard driving. Much blow by? compression good? still going good?
my engine has done 108,000km and i know everything is in correct working order because i do the servicing and fixing of the engine but i dont want to go blowing my bottem end so soon. Ive raced my car a fair bit, 10 runs in 1 night at calder with massive burnouts running 12psi and no blowby.
If i can hear what your opinions are i would appreciate it, thanks.
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
