Bro, clearly all go and less show - my style! Nice and clean - has the goods. I like it.
Damn, any vehicle that runs a 13 sec pass is damn fast. damn fast.
Hit the 12 sec mark and you can call your beast - FAST...
Good luck... hope to meet you soon.
REgards,
  • Replies 172
thanks man, just got it running today, haveto run the clutch in and still get it tuned with the z32 and hook my boost controller up, f**k it feels so good driving it again!!
my first full build up!! and at the age of 18!!
I feel ya G - damn tight.... good shyte... start early as when you're older, you got no money and no enthusiasm.... i'll be watching closely with interest on your beast.
car was tuned today.. made 206kw at the wheels on 14psi standard turbo and actuator.. actuator is letting us down with not holding boost but shit happens..
MASSIVE thanks to rob and daniel at creatd motorsports... they go to all lengths to help you out on anything that is needed, i cannot hold them high enough..
went to calder drifts had a ball there, but bowed out mid way thru the night due to a broken water pump...
i want to put a koyo radiator in now with another std rb25 pump... which koyo do you guys think is good? the type s seems good for under 500 bucks...
Nice Build up mate. should be the goods with that 30/40 strapped to the side. Just remember that its not only the bottom end that will break, gearboxes and axels will go aswell with 340rwkw and slicks on the strip...unless your real easy on the launch. but hey all the best and i can wait to get my new turbo on my car. mine is i bit more bling bling than yours tho.
Andrew
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
