Bro, clearly all go and less show - my style! Nice and clean - has the goods. I like it.
Damn, any vehicle that runs a 13 sec pass is damn fast. damn fast.
Hit the 12 sec mark and you can call your beast - FAST...
Good luck... hope to meet you soon.
REgards,
  • Replies 172
thanks man, just got it running today, haveto run the clutch in and still get it tuned with the z32 and hook my boost controller up, f**k it feels so good driving it again!!
my first full build up!! and at the age of 18!!
I feel ya G - damn tight.... good shyte... start early as when you're older, you got no money and no enthusiasm.... i'll be watching closely with interest on your beast.
car was tuned today.. made 206kw at the wheels on 14psi standard turbo and actuator.. actuator is letting us down with not holding boost but shit happens..
MASSIVE thanks to rob and daniel at creatd motorsports... they go to all lengths to help you out on anything that is needed, i cannot hold them high enough..
went to calder drifts had a ball there, but bowed out mid way thru the night due to a broken water pump...
i want to put a koyo radiator in now with another std rb25 pump... which koyo do you guys think is good? the type s seems good for under 500 bucks...
Nice Build up mate. should be the goods with that 30/40 strapped to the side. Just remember that its not only the bottom end that will break, gearboxes and axels will go aswell with 340rwkw and slicks on the strip...unless your real easy on the launch. but hey all the best and i can wait to get my new turbo on my car. mine is i bit more bling bling than yours tho.
Andrew
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
