  • Replies 172
hey dudes... im currently looking for a set of rims.. i want a set of BLACK uras rims in 8.0 and 9.0 wide with +30 offset with tyres.. dont haveto be PERFECT tyres but in ok condition, rims haveto be pretty schmick.. looking to spend around the 1grand range..
pm me with details IF you have what im looking for..
cheers ;) Phill
  • 3 weeks later...
well people, i have taken this to 2 calder drift nights and one winton drift day... and i must say i absolutely love calder and the way you can hammer it around that track..
So far the quarter panel has taken a beating but thats not going to stop me from getting better :D
Soon the 35/40 will be on with standard plenum and cams and going for 300kw on dyno.. im just waiting on Slide to finish my comp cover off and send it back...
So stay tuned :(
oh and i got a set of rims.. 17x9 all round :D
new update....
Next month my car will be off the road and the new turbo/plenum setup will be going on it.. still decided what to do with the plenum so ill leave it upto Rob at CREATD and what power the car will start off with...
Hopefully around 270kw so i get the feel of it then around 300kw and ill leave it at that untill i get a twin plate later on ;)
So stay tuned and i will show progress pics and results when the time comes :worship:
  • 1 month later...
bump this thread died on its ass...
any how heres an update
car is currently at creatd motorsports getting the turbo side and plenum done then it will be tuned then im doing my own thing to it.. picked up an earls oil cooler and fittings for it, an rpm 4point harness and ill be buying a 6point cage hopefully after that.. then drifting again :thumbsup:
will post progress pics and final product!!
  • 1 month later...
Nice build up mate, well done.
I'm watching with interest to see if the .63ex housing can flow 340rwkw. The Mafia made 300 on a 3076 with .63 running water/meth, I dont know how much difference that would make but either way should be very interesting.
Good luck, keep this thread alive!
  • 4 weeks later...
car is nearly finished.. greddy plenum is on and everything else is good, just waiting for the call from rob..
wont be pushing over 300 for now.. untill the twin plate goes in..
  • 1 month later...
car is finished :P ended up making 295kw at the wheels on 18psi..
BIG BIG thanks to the guys at creatd motorsports.. best workmanship, quality and reliability.. Rob Dan and Gas did a killer job on my engine with hiding wiring and setting everything up, spent hours on the dyno and on street tuning it, to come up with a very safe and agressive tune.. a workshop ill be happy to support with stickers on my car :P
Thanks guys :P
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
