got the car dynod. less power then i was hoping for. but then half that is due to the bad tune the car has as showen by the A/F ratio. car runs insanily rich downlow but gets to about perfect up top.
im not too worryed about the lowish rwkw. the power curve is really nice and it holds peak power quite well.
not sure what timing i was running on the day.
its about the same power of a stock r32 GTST
so what are your guys opinions of the over all result?
overall im happy with it. alot of people are impressed with it.
now all i need is some coil overs to sort out the handling and somthing to sort out the A/F ratio to lean it out down low.
https://www.sau.com.au/forums/topic/110112-rb30de-dyno-results/
it is a lovly power curve even if i do say so myself. interesting how the peak Kw stays there for pretty much 2000rpm...
its impressed everybody that has been in it so far. but most importantly im happy :mad:
haha yup its plenty of fun.. its going to be interesting on 205 crap tyres at the drags tomorow on a bad surface with gravel cus its a airport runway.
i already spun them up accidently with out even trying.. stupid torque.. haha
yeah not sure weather to get safc or just to go for a ecu.. but then i need to get my other mods.
first of all i need some $$ :no:
torque is only like that due to the air fuel ratio being so rich down low and the tune isnt right. once i get a air fuel controler it should be alot smoother.
there is a good write up with pics in the thread "my rb30de"
heres the basic specs anyway.
compression is 10.43:1, stock r33 rb25de ecu, custom extractors and 2.5" mandrel bent exhuast.
intake is just a stock rb25de pleninum with custom 3" intake pipe and pod filter.
stock injectors, fuel pump, cams. runs VVT or VCT
haha how fun it is to be spinning up through first, 2nd and half of 3rd in the drags even when your only launching at 1500rpm. sittin on the spot at 3500rpm
the surface of the track was absoule crap with plenty of gravel. my best time for the 200m was 10.5 still good fun tho :)
Hey Geoff - thanks again for the blat, I've always wanted to see what an RB30DE felt like... I love the effect having the motor balanced has had on the old RB30E bottom end :dry: Sounded very nice as well, particularly the induction noise.
Going in the car you can tell the motor would like to make a bit more grunt with some tuning.
FYI though - that dyno graph doesn't show your car running rich down low, it shows you running lean... then dropping down to a safer but still a bit lean air fuel ratio. So yeah, if you get an S-AFC - if you're going to make any adjustments before putting it on the dyno... bump up your fuelling down low.
GDAY . Those figures seem ok to me . High performance imports magazine got close to that figure with an r33 rb25det after a good tune and a few minor mods .
My engine is very close to what you have , and my times at the drags ( 1/4 mile ) are near identical to what a stock r33 rb25det should do .
The difference in my engine is 370 cc rb25det injectors , twin throttle bodies and i run an apexi safc 2 .
Edited by dondesoto
cheers lith
the only reason i thought it was running rich was cus thats what andre told me. plus that would explain the poor fuel econmany even on long distance driving. but then again that might be down to the tune of the car plus being an auto ecu...
yeah don im now sorta aiming towards your mods to help gain performance etc. i will be interested to see your dyno results when you get yours done. how long till you do your one? how did you tune the safc?
cheers lith
i been thinkin about getting it dynoed for the last 2 years , cant rush these things .
the safc tuning kind of guessing . As i run a rb25de ecu and i have an engine 20 % bigger , i justed figured it needed at least 20 % more fuel plus a bit more for having more air via the 2 x throttle bodies and extractors . From idle to around 3000 rpm it has an extra 10 up to 30 % at high throttle 3000rpm and above 30 % . low throttle settings are all set at 5% below this
get it dynoed and tune it at the same time
most prfessional dyno guys have lots of experience with dyno tuning and u might find a better result after a couple hours on the dyno tuning the ecu/safc2 properly
then at the salt lake trials u might run ur magic number of 240kph
Edited by usherly
yeah i have now realised its running lean. i had to sit down and think plus listen to my mate lith and then understand the airfuel ratio.
iv knocked back the timing a little just to be safe. but i need to get an airfuel controler to sort it out properly.
still got a slight oil leak.. but i have found where it is now.. stupid external oil feed this time down by the oil pressure sender so thats gona be fun to get at.... now i have learnt to lock tight on everything...
AHA got that wrong . i dug out that magazine i quoted from HPI 48 . They tested a r3 4 door auto RB25DE and base figure was 105 rwkw . They played with timing , air intake and tried a fuel cut defender and got it up to 121 rwkw .
true true. yeah you can gain a bit of power with a good tune and good timing easy. thats what mine needs.
i will probly get mine dyno tuned once i have the bits i need to get this all sorted. i.e rb25det injectors and air/fuel ratio controler
hehe damn it sounds scary in tunnels :(
Dondesoto: can u pls scan the page and upload them?
thanks!
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
