pplz i brought a power fc off a memeber on here just finished rebuilding my motor went to start it today and the power fc wont start the car when i turn it on and the fuel pump wont stop running and all the lights on the dash flicker
so i grabbed a standard ecu and it starts can somone out there help me asap as im in need of this car so i can go away
https://www.sau.com.au/forums/topic/110114-power-fc-wont-start-the-car/
yes series 1 and series rb25 use the same model powerfc.
the only suggestion i can offer is to
check the powerfc is connected properly (loom plug is in OK)
no bare wires on the loom are shorted out
no wires loose or not connected properly
the powerfc doesnt have a burnt smell to it
does the hand controller come up and run ok if you just turn to ON and don't start the car? like can u actually use the hand controller like this?
umm no boost kit that i know about but how do i turn it off also no burnt smell the screen flashes with the sound of the clicking of the car its lights up i might try the power fc on a mates car
how do i turn the boost kit off i dont think i have one ???
try it witha jumper battery connected, noticed mine turns off and will not start the car without heaps of power..
plus it always turns on the dash lights then switches them off, clicks then they come on and car starts..
i cant get into the menu the screen flashes on the hand controller the relay in the back on the car in the boot next to all the fuses clicks as well while trying to start
i pmd the guy who sold it to me no reply yet
it was brand new im just hoping i can fix it the car has being off the road for 5 months now icthing to get it going
if i put up the numbers of the ecu can someone tell me wat model it is for ??????????
on the side of the ecu it should have the the model number
your looking for ECR33 or RB25 something something which should confirm the model number. its on a white sticker
when mine was fried the screen would go crazy and make constant ticking noises and never boot up
well the way i figue it can be the relay cause the stock ecu starts it no props im goin to try the power fc on my mates car today and ill post some numbers up if i cant get any futher with it
johnny cash : slept like a log just finshed work at doms
hey, mine did the exact same thing when we had the AFM wired up wrong. All the dash lights flicker on and off, the fuel pump goes flat out, and then eventually the fuse blows and the dash stops flickering.
Scared the shit out of us. No damage to the powerfc, just a blown fuse.
If its not the AFM, it will be something else shorting the f**ker out.
Good luck mate, and be careful.
