thanks, thats great. however it claims a 0-100 time of 6.3? for a stock 32 gts-t? i thought they did 6.9 stock.
If you already knew the answer, why did you bother asking the FN question?
And how come no-one else has ever thought of asking this question in the 4 or 5 years these forums have been in existence?
i dont the know the FN answer, smartass. i wasnt 100% on thae answer, my knowlege is they run high 6's stock.
because this is SKYLINE website, i thought someone would have the factory time.
