I never thought to check the piping out. Ill have a look in the morning. If it doesnt happen to be that, i'll have to bring it to a mechanic i suppose. I'll let you know what happens anyway arbess.
poor GTRs dont like surviving on uni wages any more than a uni student does
in regard to what needs checking: its all above, weve told you. we cant do much more unless you get a reading of the fault codes or use some intuition and take apart the piping, pull out the AFM's and get them tested. An auto electrician can test stuff like coil power packs , AFMs etc if you dont have the right tools
if you cant afford the call out then it may be best to bite the bullet and sell the car. shes got a big belly and likes to eat your cash :P
Your absolutely right! i can watch in amazement my fuel magically dropping before my eyes! They do eat cash!
Oh and also try talking nice to the car.....i threatened to sell her once and she wouldn't start for 3 days!!!!! No joke!
lol thats like the "talking to plants make it grow better" kinda thing. spread the good feng shui and you get positive energy. heheh. I admit, i say sorry to my car if i ever accidentally go over a pothole or bottom-out on a speed bump. pretty sad :ermm:
You sold your gtst for a GTR? true though with thrashability. thrash a GTR, and in the possible case it goes bang, expect to pay big bucks! :D
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
