Im getting 4 new K104's put onto my Stagea this weekend, $800 all up fitted balanced etc, for 235/45/17's onto my new R34 GTT rims - Im in SA by the way.
How long (ie kms) would a set last for? My Stagea isnt a daily driver, and when driven is usually in high density areas..... ie city driving. The Stagea is a heavy car, around 1900kgs with me driving it and fully fuelled - so how much PSI should be in each tyre?
For such a heavy car the K104's are the wrong load rating.
U will need the K107's. Check with the tyre shop who is supplying them.
Oh? ok, I think the car is around 1650kgs standard. And I know that a Stagea driver in Melbourne is using these hankook 104 tyres on R34gtt rims at the moment and says they are fairly good.
Plus the 104's are load rating 97Y I believe, whereas the basic tyres on my car atm are 92Y load rating, and it was given a road worthy certificate (in Qld when I bought the car) based on these current Nankang tyres.
The K107's are 94Y rating... so what is best? low Y or high Y rating? from what I understand the higher the Y the bigger the load capacity per tyre, see http://www.michelin.com.au/tyres/tyreBasics_speedRating.asp
At the end of the day the Stagea weighs in similar to a VS wagon, or a Magna wagon, so Im sure the 97 rating is aok. Plus from what Ive read they are worth the cash, so Im getting them anyways (plus my budget is a max of $200 per tyre, for 'performance' tyres).
So..... what PSI should I have in the tyre?
Cheers for your information - Brendan
Edited by Tangles
I'd put them on.
I love them. I have travelled a lot of ks on my K104s.
They grip very well.
Tangles, you wont be dissappointed.
Especially considering the price.
If you are putting on 235 17s, let me know.
I'll get you a decent price over here in Mitcham.
BASS OUT
Cheers fellas (by the way Im in Adelaide, so Im not sure our Mitchem here near Unley is the place you mean Bass Junky).
http://www.hankooktyre.com.au/v2/products/...ch=uhpt&id=1088
K104's for 235/45/17 stated as 97Y
I already bargained the shop down a little in price; Im happy (sort-of) to fork out $800 for my first set of 17's provided they look phat on my porky-wagon, perform very well, good value for money, and last me a long time - I drive less than 8000kms per year.
The tread pattern seems fairly aggressive to me, and they have had good reviews here on SAU........... but it comes down to psi also at the end of the day, so that they perform and last well. I will slowly be adding SK's suspension parts over time, although I wont be lowering the car via springs/shocks. At this stage adding swaybars & castor, and will add subframe alignment kit & camber when I can afford to.
Cheers, Brendan
Edited by Tangles
about $185 each....
Good pricing.......
I probably could have rung around more places and got them slowly down a bit, but how far do you go?!
Im sure they will be worth every dollar..... I hope. Im thinking start off with 36psi in each tyre and see how they wear and handle.
Never had 17inch mags before, cant wait to see how the GTT rims & 235wide K104 tyres look on the swett-as Stagea RB25det-smokin station wagon. :happy:
Cheers to you all, go the Crows.
Brendan
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
