If the centre tailshaft bearing is worn, how hard is it to remove the driveshaft
and change the bearing?
Is is a common thing?
Taking of from first gear you can hear a little bit of a rattle, after that it goes away until you
come to a full stop and start moving again.
Edited by lows_13
https://www.sau.com.au/forums/topic/110142-centre-driveshaft-bearing-worn/
If the centre driveshaft bearing is worn, how hard is it to remove the driveshaft
its a gearbox 'open-up' problem. leave it till it gets bad/worse/breaks (maybe never) & get a second hand box or spend the money getting the box opened up and bearings changed now but it will cost a far bit.
He's asking about a tailshaft not a gearbox bearing.
It's been a while since i looked at one and my memorys a bit sketchy but it's not a hard job, unbolt the tailshaft at the centre mount and the diff, slide it out of the box, take to the centre uv with a couple of spanners and split the tail shaft in half.
There is a big nut that holds the flange on that you will expose when you split it. Undo that and slide the flange off, then slide the bearing off. It may need persuading with a big f%$koff hammer.
Installation is the opposite of removal, just make sure you mark everything beofre disassembly so you can align it all properly when putting it back together.
If you have the back of the car jacked up you can get away without dumping the gear oil everywhere when you remove the shaft.
Yeah sorry meant the tailshaft, going by that it seems pretty simple.
Is this the same procedure for the shaft between the g/box to the rear diff?
If its only making a slight knot on take off, is it something that needs to be changed
fairly soon or will it last forever and just get louder?
Edited by lows_13
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
