Hi Guys,
As you can see that im selling a bit of stuff. I am giving the garage a bit of clean so selling heaps of parts:
1. Airbox for POD - $60 - shields pod from heat in engine bay. - SOLD -
2. Turbosmart BOV Type II Veeport - $120 each - SOLD -
3. Standard R33 Coils x 6 - $150 lot - all working condition but not strong enough for high boost power output.
4. Aftermarket Ignition system for R32/R33. Purchase from SDU – runs coils on firewall setup and leads to each plug. Couldn’t get the setup working on the r33 but the r32 works well apparently, needs rewiring but easy to do. $300. Comes with coils and high-end ignition leads.
5. Cooler Piping for Hybrid Cooler - $250 comes without turbo smart bov. 2.5’ from Turbo to Cooler. 2.5 which turns to 3’ straightaway from Cooler to Throttle body. Special 180 degree bend to save on piping over the rocket cover to throttle body. Custom Piping made and includes all silicon hoses and clamp. Requires standard blow of value to adapt onto vehicle. It also has a turbo smart blow of value on the turbo to cooler pipe which is under the guard. This piping has big flow benefits than the standard equipment as top end power is improved dramatically due to the increased airflow diameter
6. Greddy Brand New Exhaust Cam Gear - $250
7. GTST Fuel Pump - $80
8. GTR Fuel Pump - $120 - (NA) Cant find it at the moment
9. Ignitor Module for r33 - $100
10. Malpassi 2:1 Regulator - $90 - SOLD
11. Plumbback BOV System for r33 - $40
12. Oil Catch Can - $80 - SOLD
13. POD Filters (3x 3'' & 1 x 2.5'' - $10 each
14. Standard Rear Exhaust (of a gts). $60
15. Standard R33 Clutch 80km - $70
16. GTR Standard Centre Gauges -$120
Im in melbourne and pm me for more details or if you want to purchase it. Prefer melbourne buyers but will send interstate. Im negotiable if your buying a couple of items.
Cheers
AK
Edited by WLD747
https://www.sau.com.au/forums/topic/110148-r33-garage-cleanout/
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
