dude, it is a NA auto 4 door. slowest skyline combination possible. Sp23's are pretty quick little cars for a 4 cylinder. the outcome is probably correct.
It seems the N/a seden R34 Auto have lack of power....have anyone out there got the same problem???
I got killed by a Auto Mazda 3 sp23 another day.
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2030636
Hmmmm.. he's right... You would be doing better if it was the coupe and manul... your 4 door ( weight) and auto ( tricky to use revs to your advantage ) is at a considerable disadvantage.. You can still make it look nice though :D
My r33 GTS is pretty fun to drive around in, ( 2 dr manual )Maybe consider selling your auto and get a manual?
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2031506
The R34 N/A 4 door is just a simple commuter car (pretty much a commodore of japan)... I wouldn't be expecting blistering performance out of it. The mazda's got better power to wieght than your car.
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2031524
arnt mazda Sp models all turbo charged i read the mazda 6sp comes 4Wd and 190KW not sure bout the mazda 3 though
no
there are plans for a 2.3L turbo moror (160 kw from memory). MPS 6 (awd), and hopefully, MPS3 (fwd). If they go into production, the MPS3 takes about 4 seconds to go from zero to speeding (100).
The SP23 is an older Mazda3 with extractors and a few other tidbits from the factory. Better grip, too, which was impressive for a passenger few to begin with.
Enjoy the 4 door skyline. Easy to drive (auto), looks good, space for mates. Probably only as fast a bommodore, but thats with alot less cubes.
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2038773
  • 3 weeks later...
Hi, you may be able to get a little more power with a better air filter and exhaust mods (extractors & so on) to help you out, but I'm sure if you had had power as the first priority when you bought the car, you would have got a turbo in the first place.
When I had my R32 GTS4 (2L turbo, manual) it felt pretty dam good compared to what I had been driving. Weighing in at around 1450kgs it was par for acceleration as a R32 GTS25 (auto) with the above done to it. SO I think with the extra kgs my car was carrying and the mods he had done they sort of equaled out) .
The best I did to 100km/hr was 7.5 secs with a mate stop watching(not the most accurate but...) with a 4.5 k launch, which is pretty dam slow! factory specs for new were 6.75 secs so age and the fact it was my car (wasn't going to do a 6 or 7k launch) hadn't really slowed the car a lot.
I learnt pretty quickly that I wasn't go to blow people away at the lights and that I had to make use of the cars other abilities - like cornering, braking etc if I wanted to stay in the lead (all on a race track of course).
I would say your R32 2.5 is fairly heavy like my old GTS4 and with only 200cc more than the Mazda you have to expect that it will be hard to get one up on them.
Like the others have said , Enjoy the other aspects of your car, its not all about power. Otherwise you would have a GTR ...
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2081850
I have an R32 GTS25 and i wouldn't say its slow, but it would get killed by an SP23 easily... I have an R34 GTV auto 4 door coming in from Japan at the moment, and I expect that to be even slower again because of the weight increase...
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2095871
  • 3 weeks later...
I am plainning to get something bigger in size..this is what I am after
If for power, I got my GTR
If for slide, I got my AE86 ready
But this one is for daily and storage.....currently looking at the Forster GT, WRX Wagon.....another good one people can think of?
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2150622
AE86? haha. did you spend 2 months tuning the suspension takumi? are you gonna go to Mount Akina?
nice avatar, kid drifting his bike.......
but really, if you are *not* after power, why complain at the lack of it?
hmm, get a stagea. auto, rb25det, volvo looks with a gtr grip - auto.
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2151457
Dude,
you watch too much movie mate.....what the fu*k you will spend 2mthon the suspension on the damn spring rates etc.....and believe or not I've been the Akina mate.....but not with a 86.....I was in my agrent's mpv....so there you go.....
And it is ok to watch some movies. but dun trust or believe it at all.....I dun want to see you or your car on the newspaper someday. :P
So watever, Initial D, Gone in 60 sec etc.....dun believe it man~~Do it in GT4.....atleat you wont damage your car :D
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2152779
y not just upgraded to a 34 GTT
https://www.sau.com.au/forums/topic/110170-my-r34-gt-4door/#findComment-2153339
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
