R33 v spec with lots of good parts over 300kw at all 4 wheels 320km speedo ,rays race wheels ,bigger turdos arc oil cooler goes great nothing to spend serviced every 5000km quick track tracker $47 000 ono this is truly a great car:mad:
https://www.sau.com.au/forums/topic/11018-r33-vspec-gtr-4-sale/
