1994 Nissan Skyline
86xxxkms
12 months reg to who ever buys it
Car is immaculate and insude is like brand new
All orginal features, climate control, power steering etc
19 inch fusion rims with new rubber
lowred 1.5 inches with lovells
3 inch cat back sports exhaust
hybrid front mount intercooler
Pod with heat shield
Turbosmart Vee port BOX with adaptor
Carbon Fibre bonnet
Strut brace
Sports wheel
Panasonic MP3 Player ($600rrp)
3 gauges in single Din position, Volts, Boost, A/F
Will also throw in a 4 GIG IPOD
CAr is running stock boost. very clean will not find better
$16,000 ono
0407686611
Matt
Edited by XXE-R32
https://www.sau.com.au/forums/topic/110186-fs-white-s1-r33-gtst-vgc/
how negotiable is that price?
the 12 month rego would not be necessary as i would have to re register it in qld.
have you got service records to back up the km's?
I am neg on the price sothat is not an issue. I have full log books from japan with the car as i requested the car i import to have this.
If u need some more info please call me
0407686611
did u change the front headlights?? are they the series 2 ones thats clear?? or is it still the foggy series one?
Still have ur old bonnet? willing to seperate the cb bonnet?
Sorry selling the car as is.
the headlights are the s1 just i cleaned them to get them so clear
fark that is getting cheap, and it's so hot!
Any accident history?
Whats the service history like?
How modded was it when you got it?
And how long have you owned it?
Interested in Trades?
No accident history at all, it has full log books and serviuce history, it was stock when i got it and i have only had it since january i was the first owner, looking to upgrade to somehting bigger, commodore, falcon, etc
CAr is still availble
check your PM. thanks
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
