mate if I could give you a deposit would you be able to hold the car for me? I know you're in a hurry, but let me know. Thanks
i would rather have the money before tomrrow or tomrrow as i am going away nextr week andf the new car will be here sunday
just a word of advise i got the money for my last car with in 2 hours so i cant see thatbeing a problem
car is now 14k
Quite interested for a mate of mine...
We are looking at a few lines this weekend...
Would we be able to hva e alook at it this weekend?
Cheers,
M
sure i will be at lansvale in the morning if you are interested at 9am. I also was looking for a car today and the price of skylines are BS, not as good as mine withj more kms going for high teens
buy mine u cant go wrong 14k firm
i thought you were getting rid of the car this morning. if you haven't let me know. I'm really keen on this one. thanks
Sold for 14k to a wholesaler
went to his yard this avo he has 17900 on the car
These people are RIPPOFFS
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
