Yep i have the same issues :O with my 1989 R32 GTS but i dont think there exists an easy fix for this kind of problem, other than replacing the dash $$$ :( or peeling back the dash vinyl and replacing it which would be tedious and difficult. :yucky:
If any1 has any suggestions i would love to hear them!
Edited by LoNg_ShaNks
https://www.sau.com.au/forums/topic/110190-bubbles-in-dash/#findComment-2043528
Tools required:
* good strong hair dryer or heat gun (careful that you don't scorch the vinyl if you use a heat gun)
* 10 or 20 mL syringe with narrow gauge needle.
* large tube/bottle of Super Glue
* Acetone for removing spilled glue (and cleaning needles/syringe if reusing)
* "1/4 round" wooden moulding for pressing into the crease of the dash
Reading the list of tools you can probably work out the sequence of repairs:
* heat one "bubble" at a time so the vinyl becomes soft and pliable
* have a (very freshly) loaded syringe and needle ready and inject into the bubble from the side
* press firmly into the crease with the quarter round moulding and hold for a few minutes (take care if glue spills that the molding doesn't stick to the vinyl)
* clean up any spilt glue with acetone and wash syringe/needle if you don't have any extras at hand.
https://www.sau.com.au/forums/topic/110190-bubbles-in-dash/#findComment-2046663
Thanks for the reply gav. Sounds interesting
Have u done this before? I wonder what kind of hole the syringe will leave. Obviously ill go for the thinnest point i can find.
1/4 round mould. is this something u can pick up from diy homewares store?
1/4 round mould is simply doweling that's been halved and then halved again - available from hardware stores. I just happened to have some lying around at the time.
https://www.sau.com.au/forums/topic/110190-bubbles-in-dash/#findComment-2047605
