This is my 1993 Nissan Skyline R33 GTS25t sedan. I privately imported the sh*tter through Autoworx as stock standard with 76,000kms on the clock.
ENGINE MODS
'China Spec' 3" stainless steel catback exhaust
'China Spec' 3" stainless steel dump/front pipe
K & N Air pod filter
Turbosmart Veeport Blow Off Valve
'China Spec' 600 x 300 x 76 front mounted intercooler w/ 'China Spec' Aluminium piping
INTERIOR STUFF
Recaro SR3 seats
AutoMeter 5" Monster Tacho
Defi BF series Electronic Boost Gauge in Greddy A Pillar mount
Defi Gauge Controller
Apexi Auto Timer
Kenwood CD player
Custom PPG Colour dash Surround
Custom Blue suede gear surround and handbrake cover
Nismo leather knob
Isotta Nivola steering wheel
5% 'Limo' Tint
SUSPENSION
Kei Office adjustable coilovers
WHEELS
20 x 8.5" DUB 'Big Homie' wheels with 225/30/r20 Nangkang tyres.
I will admit it is a SLOW CAR with MINIMAL ENGINE MODS, RICE spec if you wish :(
Havent had any problems with it though, runs perfect and is yet to be boosted.
Its a good looking, clean, reliable daily drive which is all I was after.
Hope you enjoy :)
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/110218-my-whale-spec-family-sedan/
nice car man.... very neat indeed....i like how u kinda left the sleeper look by hiding the fmic. thats kinda how i wanted mine to look but i butcherd my bar instead.....im not normaly a fan of chrome but their soo huge ive gota like em!!
yeah kept the "go fast" mods hidden coz it doesnt go very fast at all :O
have also modified the cat for big flames :P
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
